Problem with Matched Photo
Hi! By accident I imported a photo as -Matched as Photo- now I realised it a bit late, and all my proportions are messed up. How can I undo matched as photo and get back to my normal perspectives? Thank you!
Hello, it is probably your Field Of View that is messed up. click on the zoom tool, you then have two choices, you can directly type an acceptable value at the bottom and press enter (for example 40 degrees), or left click and drag while holding the shift key.
there is also a button to reverse back to the previous camera view, in case the problem just happened
If it is just that you are stuck into the match photo tool, right click anywhere and choose done. Then delete the scene tab created by match photo
Thank You very much!! Actually it looks better again!
