Hi every body
I have a problem
My model dimension with shape that draw dont mach
Ex: model is : 14.82m
But shape is : 0/05m
This shape draw on a part of model
Hi every body
I have a problem
Share the LayOut file so we can see how you have it set up.
Is the shape you are referring to drawn in LayOut? Are you using Scaled Drawing? Did you set the scale to match the scale of the viewport?
I can’t tell what you have going on in your LO file from a couple of screen shots. Please share the LayOut file.
Apparently your dimension has been disconnected from the model so it shows the paper dimension.
