Problem export from Rhino to Sketchup
Hello everyone. I am working on Rhino6 to make a model with different slopes… Then I want to export it on Sketchup - but it is creating me all this kind of strange geomerty in the different block I made on Rhino. Is there a way to avoid these kind of problems ? Thank you !
Are you working to a very small scale? The missing faces could be a result of that
In Rhino I find it safest to convert my polysurfaces to meshes before exporting to SketchUp. I usually also use the ReduceMesh command before export because to my taste, the default Rhino exports contain far too many polygons.
Thank you I’ll try to change the unit because yes I was drawing in Millimeters and meshing the srufaces thank you !
