Cant export a rhino file to sketchup
Hi,
im trying to export a rhino model into ketchup but it doesn’t work.
I already tried skip, which failed, dwg, stl etc.
I don’t use rhino so I don’t know if there is any setting that I could use.
Please help
thanks a lot
When you export from Rhino to SketchUp, you should set the polygon count to the lowest setting. Even that is most often too detailed for SketchUp. I have found that before exporting it is best to first convert your model to meshes in Rhino, and then use the available polygon reducer command to make it very much more coarse.
How can you export from Rhino without using it?
