My settings
And what I got
Why is there still the logo, and what happened to scaling? It should not take an hour of farking around for a simple print with dimensions.
When you print you get exactly what is visible on your SketchUp scene, all the white space included. It is like a screenshot. The logo is a watermark that is on all the free Web version model views. If you are using Pro or Go you should be able to remove oit.
My license is PRO. There was no option that I could see to remove the SkecthUp water mark.
There is a scale option that from what I can see does NOTHING. By trade I am an electrical engineer/embedded programmer, and have been using Windowing systems since DeskView/X, sadly I find the UI in SketchUp is not obvious or intuitive. Could be a documentation issue as well, it is a ■■■■■ to find little things like this. For example calling the window outliner to see object hierarchy is a ‘huh’ movement for me. What is wrong with just calling it, say, “Objects” or “Hierarchy”. It is like you need to be in a club, and the documentation is not a quick way to become a member of that club and gain the community knowledge.
It should be in Style settings.
Printing works better through the LayOut application. You can even set the scale.
