Hi All,
Strictly this isnt directly a sketchup post but i have created a layout file from a sketchup model, in Layout the viewport is a 2d drawing set to 1:1000 scale as the model is in meters and i want to print it to scale. I am exporting to pdf and then opening in Adobe Reader but when i try to print as a poster it is spreading the image over 8 pieces of paper when it does fit on 4.
Here you can see when printing normally and set to actual size you can see that the image would fit on 4 sheets of A4 but when i select poster it does this.
Ive tried changing all the settings but it makes no difference.
Does anyone have any suggestions?
Here are my files if you want to look at them.
Table Saw Brackets.skp (259.7 KB)
Motor Bracket Template.layout (297.3 KB)
Motor Mounting Bracket Template.pdf (18.0 KB)
Thanks in advance.
Dan
