It looks good as an .STL file but any slicer program sees large gaps and incomplete surfaces. Even the flat faced normal surfaces don’t come out well. I used Curviloft for the curved surfaces.
I really need some help here and any help is greatly appreciated!
I don’t know what you did, but there is a lot of hidden junk in this model, which becomes visible if you do View->Hidden Geometry. Try cleaning it up and see if that helps.
Edit: also try applying Solid Inspector 2. There are a lot of flaws preventing this from being a solid. They are going to mess up any export that tries to handle this as a solid!
I think that may have fixed it! I tried solid inspector a few times but never thought to explode everything before hand, I figured that making it a group would help the issue.
