Hello, Could some please help me fix this problem I’m having with Translucency? I’m coloring an object black both on the outside and inside and for some reason when I save it as an FBX file and go to preview it I see right through the object. I’ve provided an image that explains my problem. If you have any questions please let me know so I can try to explain better if you don’t quite understand. Thanks.
Just a guess … View the SketchUp model in Monochrome.
Are all the faces oriented such that the front side (white) is facing outward?
