Please help explanation
Please help explanation. I use GooglesketchupWen.exe to design machine components with detailed animations that require a round on some details of the components that I created. I want to ask what should I do so that my design image can be moved with each component corresponding my purpose ?.
We explanation for my trouble, and thank you very much for your cooperation.
Hi,
I think more information here would be helpful.
until then, search this forum for threads containing… “animation”, and I think you’ll get most of the recent discussions on this topic. . . some are concerned with smooth rotation, others are dealing with the scripting of animations.
I’m not sure what you’re really looking to do. When I see/read… [quote=“MaximuzWelding, post:1, topic:24561”]
[/quote]
I get the impression that things might a bit more complicated than the typical SketchUp animation.
What’s the context with all of this?
Is “each component” independent of the others in the way that it rotates or moves around?. . . Are there counter-movements going on between the components?
What needs to happen for the components to be “corresponding” to your purpose?
Are the “Machine Components” rotating at different RPM’s?
You have a couple of sentences that sort of imply a lot.
I think if you wrap this up in a few specific goals, and post up screen shots, and preferably the .skp file of your model, that would be helpful, and you’ll likely start to get real answers to your question here.
