Ok - this is my problem. I need to send an engineer a drawing of the rebar layout of a concrete lintel beam, 18" tall x 45’ long. We got the spacing by radaring the beam. The rebar is not spaced uniformly.
Since there’s about 45 sticks of rebar, if I used the normal dimension tool, the drawing would be too cluttered. I was thinking of a single line from each bar with it’s space with the text at 90 degrees. The text tool and the dimension tools aren’t too helpful in this regard.
I thought of using Layout however, because of the length of the model I need to pan back and forth in the view port, however, when I invoke the pan tool, it moves the viewport, not the model. Any way to do that?
I’ve attached an example of what I am trying to do. I annotated the image in Paint.net, but it looks sloppy.
Any ideas?
P.S. - the beam is actually taller - this is only the portion we are reinforcing with a steel I beam. We need to spot the bolt locations so we don’t hit buried rebar.
G
