Gerson
July 24, 2020, 12:16am
1
Hello guys, could you help me? I am unable to place the component in the desired position in the library.!
DaveR
July 24, 2020, 1:13am
2
Are you asking how to change the thumbnail’s appearance to show the 3/4 view?
Gerson
July 24, 2020, 1:25am
3
that’s right.
Sorry I’m using the translator.
DaveR
July 24, 2020, 1:29am
4
No need to apologize.
When I want to change the thumbnail image I first save the component out to a local collection. Then I set up the view I want in the model space, drag the thumbnail from In Model to the local collection and that seems to take care of it.
Box
July 24, 2020, 1:33am
5
Another more brutal method is to position the component as you would like to view it, then explode and remake into a component.
Edit: Difficult with Dynamic Components.
Gerson
July 25, 2020, 1:58am
6
Hi Daver, something wrong, I’ve tried everything and the component appears in the miniature model as seen from above
Another thing, does not appear or the dynamic component symbol is not available in thumbnail
I’m on my cell now. then I’ll post the file here, maybe someone will help me with that
pcmoor
July 25, 2020, 6:10am
7
check that redefine thumbnail is on?
What version of SketchUp are you using? There was a bug in 2020.0 that generated wrong DC’s thumbnails upon resave.
It was fixed in an update.
Gerson
July 25, 2020, 9:21am
9
2020 version Mike Wayzovsk
And what to do?
Gerson
July 25, 2020, 11:44am
11
Thumbnail reset is enabled.
Strange that does not show the location of the saved file
Gerson
July 25, 2020, 11:45am
12
pcmoor
July 25, 2020, 12:00pm
13
Edit menu in the top plane on selection will show the path
another possible issue, assure bottom pane is not the home tab, pin points another folder
Gerson
July 25, 2020, 12:37pm
14
All library components appear in the current model, as seen from above
In SketchUp’s menubar:
Help->About SketchUp displays the version included the minor version number, eg. 2020.1
Gerson
July 25, 2020, 1:01pm
16
When I open the local library, right on the model.
When I track it I compensate it. in the model shows from above
