Unfortunately since I updated Su to 2025, when I use the orbit tool, the image is flipped then I can orbit. Any advice?
many thanks
giovanni
How did you update to SketchUp 2025? It hasn’t been released yet.
Share the .skp file so we can see what you’ve got setup and a screen capture video showing what you are seeing would be helpful.
BTW, your forum profile says you are using SketchUp 2017 on Windows 8. Please update your profile.
I’m so sorry, Su Pro 2024 was intended …
Cassonetti tapparelle.skp (352.8 KB)
I tried different camera views and when I tried to orbit the model it flips over and then it orbits as usual.
It seems to happen only with this file: I opened a new one and the tool works fine.
Maybe it’s something related to some actual specific file setup?
Many thanks
You’ve got your model axes screwed up in this model.
Solid blue should be pointing up. Turning on the sky in the style makes it easy to see your axes are incorrectly aligned.
Right click on an axis line and choose Reset.
With the axes correctly orineted see if your orbiting behaves as you expect.
BTW, I would suggest keeping your model closer to the origin.
