I created a 3D Model and need to import it into Oracle Spatial in order to create a spatial database and order the model into database. Its datatype should be SDO_Geometry data type in one column. How can I import and insert .skp 3D data into Oracle database ?
(1) You will need to GeoLocate your SKP model
Then for general preparing your model for export:
Viewing Your Model in Google Earth
(2) The Oracle docs say it supports OGC Standards, of which KML is one.
- So, try (after geolocating,) to export as Google Earth (KMZ).
From SketchUp menu: File > Export > > 3D Model…
Choose “Google Earth File (*.kmz)” from the filetype dropdown list.
The KMZ is a zip archive that has a KML XML file inside it.
Thanks. I got my model in KML data format already and tried also in this format. But what I can not do and can not find information is that, how can i import this into oracle dbase.
Well this is a question for the Oracle forums.
http://www.oracle.com/technetwork/database/options/spatialandgraph/community/index.html
If there is an answer it will be in the manuals.
http://www.oracle.com/technetwork/database/options/spatialandgraph/learnmore/index.html
