OpenCutList can't generate parts list
OpenCutList never finishes loading when I try to generate the Parts List… I see the “Calculating a world of peace…” message forever. It used to work. I accepted a Sketchup auto-update to Version 24.0.598 (on Mac OSX 14.3.1) and it’s possible it broke when that happened, although I’m not 100% sure. I tried reinstalling Sketchup from scratch, tried reinstalling OpenCutList, but nothing has worked. I’ve tried to make sure my components are assigned Materials, but when I try to “Edit part properties” in the OpenCutList context menu, I see the same loading message. The parts are all organized into components and were using Materials perfectly until this problem happened.
Any ideas on how to get it working again? I have tried to
Share the .skp file so we can see what you are working with.
Generate Parts List works instantly for me.
I did clean up the model first by fixing incorrect tag usage …
…and purging unused stuff.
Maybe you need to clean up the model before running OCL.
@DaveR - this was it! I am unfamiliar with cleaning up, so installed the Cleanup3 extension (SketchUp Extension Warehouse). This did the job and I can now generate parts again. Thank you!
if you have just installed new SketchUp 2024 update, I’m pretty sure that restarting your computer will solve this issue.
@boris.beaulant - I hadn’t tried that but obvious should have! Thanks for chiming in here to help and for all your work on this.
