Open Cut List Cutting Diagram - Nesting
Trying to create a cutting diagram using the Nesting feature. And I get this:
Guillotine works and Rectangle work but both produce a lot of waste material.
Same out come in both the latest 7.1 ver. and the latest Developers ver.
Some of the components nest fine individually others throw the “Dam!” message.
I’ve redrawn the ones that are a problem but to no avail.
Here is the file if that helps:
CorianForms 2026-01-21.skp (993.5 KB)
@boris.beaulant ?
Hello @fxcutting,
Thank you for this report.
In a first look it seams that the some part failed inflate of the 3/8" spacing. So we need to investigate this better.
In the meantime, if I set it to 7/16", it works.
Thanks.
