I’ve a problem on sketchup web, where the one surface, the floor of one room, appear over wall and chair.
When you move around, you can see the chair if you take a horizontal look. But when you take a look from the ceiling, it’s almost hidden by the floor. Same with the wall. You can see the top of it, but the bottom is hidden by a part of the floor (admittedly, the floor is not clipped to the exact size of the room)
Strangely, it only do that with one of the four rooms.
I’d have posted screenshot, but as a new account, my post was rejected.
SketchUp is a 3D application so if an object is placed behind another the other will cover it when viewed from that direction. When two flat objects are at the same 3D plane you will see “z-fighting” where their faces alternately cover each other when you change your view. The solution is “not to do that”.
As said, post your model to hear more accurate answers.
I’m close to the origin. I actually tried moving the whole model so that the clipping object geometry contains the origin, and it didn’t solve the issue.
The floor that appears on top of the wall is not on the same 3D plane as the wall, given they are perpendicular. And the floor is below the wall. It’s also below the chair
