I haven’t used Sketchup in ages and want to reprint this model (with clean holes where the three tubes intersect with the ring). It’s part of a light fixture I’d printed in PLA that has degraded and needs replacement (nylon). The resulting holes are for the bulbs.
How do delete I those three tubes and leave clean holes in their absence? My best effort leaves the interior exposed. I’d really appreciate some guidance on this!
Thanks for responding. I got the extension installed. The pic is after running Solid Inspector (x-ray view). I have NO idea what I’m doing, but I “fixed” it (?). Can you tell from this pic?
You need every single object to be a separate group or component. Each tube should be one, your ring should be one. If you focus on the fact that the whole model should be a solid, it won’t work. Whatch the video I posted.
Once your ring is a solid group or component, you will be able to substract the selected tubes if they are solids as well, and it will create a hole where they are
From rereading your post, to get the 3 holes in the model I’d have to group each tube separately. Can that be accomplished while they remain inside the model?
If I have to remove each one to group it and then reposition it again inside the model. I really hope they can be separately grouped while still in their current positions because I question if I’m able to relocate them and reposition them as they are. I created the original file maybe 10 years ago. My printer and Sketchup are not used very often anymore (I’m turning 80 next month).
When I installed/used Solid Inspector yesterday I ran it with everything grouped together. So that won’t work that way, right (because all these elements were grouped together b4 using Solid Inspector?)?
I’m thinking that I have to go back to the original model (everything model/tubes grouped together) and explode that and regroup just the model (not the tubes) and group that and then separately group the three tubes. Then I use solid inspector to repair each of the groups.
Hello Box! You’re still helping people after all these years. I still have a few short clips you made for me 10-15 (?) years back. Very positive memories, thank you Sir!
I would really like to just print this. I am no longer doing much design work so going thru the learning curve would be a strain/struggle. This is all about creating a lasting light fixture (that my daughter will someday have).
I hadn’t checked any of the measurements on the model I sent you and didn’t realize until yesterday I’d wasted your time. That original model file I sent you had a big problem, the z axis was almost 50% smaller than it should have been, and the ‘ring’ was sized not quite 50% larger than it should have been. There’s nothing I can imagine that would explain how that could , , ,?? Schizophrenia?
I wasted a bunch of time with the scale tool finally realizing the model would have to be completely redone. I’ve been processing that for the last 24 hours.
THEN, just a few minutes ago I realized I might not have thoroughly searched my SketchUp folder. There, in the very last folder there was to check, I found an old copy w/no tubes, just holes. It has one surface gap/hole and a few minor internal problems but was sized correctly. I ran SuSolid tools and fix’d some of this already, but there’s a few remaining internal conflicts and that surface gap remains unfilled.
Would you do a final cleanup of these last lingering issues?
Try this one. I have repaired it but it is not as good as it could be due to the way it was originally made. If you posted accurate dimensions it could be remade in a couple of minutes more accurately.
Some of the issues are, the circles have not been drawn on axis and they have different segmentation which doesn’t help things line up. The ‘tubes’ cut through the bulge at just the wrong point which causes issues. It could be redone but if this fixed model works for you I’m happy to leave it there.
Print failed. The bottom ring printed garbage connecting all three holes and one hole had nothing but support filament holding the bottom of the hole together. That hole bottom and the section of the bottom ring below it was completely missing when I removed the support filament (yellow area on top hole of image below).
I think the only option is for me to send you measurements and go for your re-do.
I’ll get on that today/tomorrow and forward the info to you. This is what SuSolid’s showing on that last file I sent you to wrestle with:
I’m now wondering ‘what I did wrong’ with that original model with it’s jumble of surfaces. If you have links or info at hand that will help guide this rather clueless neophyte, I’m willing to attempt to mobilize my 80 year old brain and reawaken my Sketchup neural pathways. (I owe us both that,)
