Objects Shifting?
What do you suppose is going on here? I went back into the model to edit a material and when I returned to Vray it shows the base shifted to the side.
In SU:
In Vray:
In an older version of V-Ray, such a problem appeared with some groups/components.
Probably if you redo the groups, it will be rendered ok.
Interesting. Thank you. I did find that stopping the render and restarting it seemed to fix it.
You’re welcome!
It means they haven’t been able to fully fix that issue since version 5 or Next.
If it reappears, try to recreate the groups.
