Both objects are grouped and unlocked, but the big one retangle box with the cones inside doesn’t want to play with me
When I try to chose the other object first there’s the error: “At least one of your chosen objects isn’t a volumebody or is locked.” It’s not the exactly error, I’ve translated it from German to English.
Any ideas? Tried to find a solution the whole day, with no result
Make sure both groups are ‘solids’.
Make sure that all of the faces in both groups are properly oriented.
That is, their ‘off-white’ side is visible - NOT the ‘blue-gray’ backside.
EDIT: I made a new project, now the big cylinder has to be subtracted, not the small one, as in the screenshot. Same in the end but other did not fit and now the big one even doesn’t work.
