I really do not understand why numbers buttons working like short cuts - camera - views. And I cant disable that function
corrected the title, shor cat became shortcut ![]()
I donāt follow. do your numbers act as shortcuts and you want them to stop ?
do your numbers act as numbers and you want them to be shortcuts ?
are we talking the top bar numbers, accessible using shift ? or do you have a side numberpad ?
did you install sketchup correctly / completely ? meaning you open the archive, then you drag the SU folder into your application folder ? some people run sketchup directly from the archive and it has weird results.
could you give info about your machine, your sketchup, and all ? right now you profile reads this (please update it) :
ā what version of sketchup, what version of mac os
depending on what the situation is, answers may vary.
Yes, my numbers acts like shortcuts, and I like to stop them.
Yes they are bar numbers, I allso have the second testature working equal.
I thing the SketchUp is installed correcly.
I tray to work on my Mac Book Pro Apple M2 Max 32 GB macOS Venura
SketcUp version: SketchUp Pro 23.0.418
please add that into your profile. Top right of the forum, click on your icon, then the small silhouette, preferences, and on the new page, profile. so we donāt have to ask ![]()
can you check the shortcut menu in the preference panel ? what does it say ?
Check a tool activated by a number, and see if itās an actual shortcut or not.
check for updates, there is a 23.1 now it might solve your problem. (check for ventura upgrades too, never too prudent)
Also, what language are you using sketchup in ?
in mac os, if you open tne system preferences, then general, then language / region, at the bottom, you can force an app to launch in a certain language. SU is always available in english in addition to your selected language, so you can force it to run in english. Does it happen in english too, or only in your language ?
right now I donāt know what could make your SU work that way. but the more infos we get, the more hypothesis we ca rule out, the more likely we are that someone comes and says āoh yeah I know that oneā
The shortcuts for the camera views are Command-1 through to Command-7. If the number keys on their own are triggering the views, that suggests macOS thinks your Command key is stuck in the on position.
If you type O for Orbit, does the File/Open dialog appear?
Yes, you right, I change details in my profileā¦
In the short cut menu (SketchUp Preferences) I can do nothing. I can see Functions, Keys but I cant change anithingā¦And there are no numbers mention in there,
Ok I will download new version.
The language in my SketcUp in English, but I allso use Slovenian testaure. In SketcUp its ony Englisā¦
Yes, if I type O the dialog window appearā¦
And yes when I type 1 appear Top view, 2 also Top view, but just move a litle bit to the right, 3 is Front view, 4 is back view, 5 is side view, 6 is side view, 7 is Isomertric view, 8 showing a rotating tool,
So why does you computer think the Command key is being pressed? Something wrong with the keyboard?
Oh, Its new mac book, but you never know, may be I can reset or reinstal keyboard?
Have you tried a power off reboot of the computer?
Yes, right nowā¦
Is there some accessibility option that needs to be changed in the Settings?
Reboot, computer, but in SketchUp all the same problemsā¦
May be I must tray in other programs like Corel drawā¦
and yes, there are some shortcuts, but they are working goodā¦an I can see them in Preferencesā¦
even just on the desktop. press N
if it opens a new Finder window, then your computer thinks your command key is pressed here too.
You say you have two keyboards, the one on the macbook, and an external slovenian one.
Your bug, I suppose it is with the slovenian keyboard. If you unplug it, and use the english keyboard of the macbook, is it still buggy ?
ā asking, so we can find if itās a keyboard problem (the slovenian, maybe the key is stuck or broken), or a mac os problem (if itās both keyboards and not just in sketchup) or a sketchup
I have instaled new version of SketchUpā¦so naw is 23.1.318ā¦but all the sameā¦
And also disconected the second keyboardā¦but nothing.
I thing that is somethinh in SketchUp settings wrong, anfd I canāt changeā¦
In the SketchUp Preferences - Shortcuts - there are functions like Camere/Standard/Views/Topā¦etc, but how to changeā¦there was nothingā¦no numbersā¦no lettersā¦nothing.
So may be the problem in computer
In the computer System Settings I found Keyboard preferencesā¦useless
Seems to be solved by disconnecting Sticky Keysā¦thanksā¦
I have a problem with tags. When I try to open or close a tag Show the whole tag collumn in orange
And is ever possible to make tekst in tag window biger?
