North arrow
I’m using skp 2023. Where do I find the north arrow placement ?
By default North is along the green axis. If you want to change it you can install the Solar North plugin from the Extension Warehouse.
As for an actual north arrow you can model one or find one in the 3D Warehouse. Generally that’s the sort of thing that would be added in LayOut instead of in the model.
Is there a north alignment plugin for 2025?
You can use the Solar North extension from the Extension Warehouse. It works just fine in SketchUp 2025.
north
