Hi,
How come when I draw a rectangle on an image I imported for reference, the extrude tool extrudes the image in the shape I drew instead of a normal rectangle like I want. Thank you.
Hi,
How did you import the image and what did you do to it after importing it?
I’m guessing you imported it as an image and then exploded it which converts the image to a face with a texture on it. Then you drew the rectangle which merged with the texture rectangle. If you skip the Explode step or if you immediately make a group after exploding the image, new geometry won’t merge with it.
That was it! Thank you!
I like that house!
That’s from Harry Potter.
