Hello. I am unable to import any dwg file from AutoCAD 2018 into Sketchup Pro 2018, not even a single square.
The Import Results boc shows up as empty and when it is closed I am told the Sketchup Import Failed, no matter what I try to import.
Please help!~
AutoCad 2018 has a new DWG file format, not yet supported by non-Autodesk applications. You should save the file in AutoCad to an older version format (2013 or older) before importing.
Thank you! That’s working now.
