Need to Convert the proper STL file which is printable
Hi guys please help me out of this
I am new for sketch up and I want to design the bench i had designed but it is not converting into g codes for printing can you please give me solution file for this. I am sending the file below
Bench 1.stl (589.1 KB)
Stool 1.stl (55.6 KB)
Orient the faces correctly, with the white facing outwards. Create a face for bottom.
pag-05
Learn about Solid object in SketchUp.
Thankyou mihai even though i tried with making solid it is not getting g code is ther any reason for that
also what about stool is there any way for it I am unable to slice it.
grafik
Bench 1 (repaired).stl (595.7 KB)
Stool 1 (repaired).stl (61.8 KB)
Hi,
here the repaired now solid stl.files.
Cheers
Torsten
