Need help on fbx to skp
hi, can someone make this an skp file? i’ve been trying to make this an skp but i can’t. Please help, thank you!
886de31fc02346af81e4b252a859cfca (1).zip (14.0 MB)
I opened it in Rhino and saved as .SKP. Rhino warned about some too short edges so it might have holes. The meshes in it are open so it is not 3D printable anyway.
886de31fc02346af81e4b252a859cfca.skp (7.8 MB)
hi, i tried to import this but the model doesnt appear to my skp. am i doing it wrong?
What happens if you just open it instead? Maybe you need to hit Zoom Extents.
I didn’t check it out after conversion before posting
  • it became tiny, about 6 cm across
  • for some obscure reason Rhino geolocates SketchUp files to the bay of Guinea (0,0), you might have to remove that
Autodesk have this tool:
With that you could convert the FBX to Collada, and then import that into SketchUp.
The Mac version doesn’t work with recent Macs, but the Windows one should work.
hello, yes it was indeed 6cm T^T it was so small and most of my models are like 100m tall and i did not notice it was there. Thank you, you’re a life saver man!
thank you! i will try that
it was very small i did not see it T^T
