This might be silly… But I’m realy having trouble creating my roof.
Could somebody please have a look how I could do this.
Untitled.skp (104.7 KB)
This thread is very comprehensive. I think it’ll cover you for all kinds of roof designs.
I’ll go back to my bridge now.
Those video tutorials should definitely get you to a solution. If you’re still looking for something specific to your model, I ended up with this: Untitled.skp (114.9 KB)
IHMO Darrell has correct approach. however you have several rake roof intersections as noted in PIC. They typically intersect the wall under the eve. Once you have the plan view then just move the ridges ( The rest of the geo will follow) up to location you want. The back section looks like it could be flat since it shows a cap line. It does not look like the chimneys intersect at the eve lines so you do not have to worry about crickets. It my be easier for you to model if you can divide the house into components so you will not have issue with sticky geo.
