My scrapbook has gone after update
I updated to the latest versions of Pro for mac 26.1.188 , and my customs scrapbooks have gone. When I’m in Layout the scrapbook windows appears but it only has the default scrapbooks.
I’ve opened a finder window and revealed ‘hidden’ folders.
i expected to go to Library > Application Support and to be able to drag something from the old 2024 version folder to the new 2026 folder, but there is only a 2024 there, and it only shows Sketchup - there’s no folder for Layout?!
where is my old custom scrapbook and when i find it, where do i put it?!
thanks in advance
paul
Hi Paul,
Have you had LayOut 2026 open since you installed it? If I remember correctly the folder you’re looking for is created after the first use of LayOut. Try this: In LO2026 make a simple page of shapes or something and then use Save as Scrapbook to save it. Make sure you are putting it into your Scrapbook collection. You should be able to find that file in ~/Library/ApplicationSupport/SketchUp/ … after that and you can then copy your scrapbooks over to that same folder. Delete the one with the shapes if you don’t want it.
I have the same issue! I don’t know know how to find my file after going thru your steps. Where do I input ‘~/Library/ApplicationSupport/SketchUp/’??
In Finder.
I just put it in finder and nothing happens
Try Library/ApplicationSupport/SketchUp under your username.
I put both versions in the search window in Finder and nothing happens. Please help as my custom scrapbook took hours to make… ugh
It may be that the Library/Application Support is hidden so you’d need to make hidden folders visible.
Not there either. I can see the hidden files and nothing.
I found on the harddrive the Library / ApplicationSupport folders but no SketchUp in the Application Support folder…
You’re not looking under your username. You’re looking under Macintosh HD.
Thank you for pointing that out. I found them! Thank u. I know you get this sort of question all the time… Really grateful for sticking with me until I figured it out, eventually!!
