HI guys, I 'm using skectchup 2024 on mac. I was almost finishing a drawing when the zoom started to play by itself and the drawing disappeared. I tried to roll the zoom backwards but nothing appears. What could I do?
Thanks for your help!
You would have either a Pro or Studio subscription, not a Classic license. Please correct your profile.
That’s definitely unfortunate. I asked you to share the .skp file so we can try to help you fix it. I haven’t seen it yet. There might be some fix for it but we’re running out of time.
thank you very much 8 it’s my first time on the forum and I was in a hurry as I had the meeting with my client. Now I’m back, I changed the licence in my profile and I would be so happy if someone tries to save all these hours lost. How do I attach a document?
If it’s 16 Mb or less drag the .skp file into a reply. If it’s larger than that, upload it to DropBox or similar and share the link.
It still shows a Classic license which isn’t available for SketchUp 2026. You put the operating system in as the graphics card. After you make the corrections you have to scroll to the bottom and svae the changes.
On Mac the backup file is in the same folder as the SKP, with the same name, but with ~ at the end. For example, if you are working on MyModel.skp, in the same folder will be MyModel~.skp.
Launch SketchUp and then click the Apple icon at upper left on your screen and choose “About this Mac”. The dialog will tell you what graphics you have. Launching SketchUp is needed because unless it is in use, the list may omit other than integrated graphics.
There are 7 objects a long way from the origin. I tried deleting those in the hope of then seeing the remainder, but that didn’t work out.
One thing you can try, open your model, and click-drag around the origin. Look at Entity Info, and it should show 1241 Entities. Choose Edit/Copy, then in a New document choose Edit/Paste in Place. That should give you the 1241 entities in a new file.
It looks like you’ve got at least a few objects at a long distance from the origin and the rest of the model. I’m copying over the objects to a new file a few at a time to see if I can determine what is causing the problem. So far I’ve found one group that is set off from the rest of the model. More to come ASAP.
I purged unused content and reduced the excessively large texture file. I also ran CleanUp3 which merged coplanar faces and materials. This has reduced your model file size by 64%. Here’s the link to the file:
By the way, it looks like you have set up your model to show five different design options. With proper tag and scene usage you could do this with a single set of walls.
