I will definitely try to Section Cut Face plug-in, thanks for letting me know that it does more than I had imagined it did!
I, too, add a scrim between my section face object and the model behind it in order to make the section face object/view/geometry/materials pop. You are correct that the feature I’m asking for would still require workarounds like that scrim to make things look perfect, it would also require serious layer and tag management to keep unwanted things out of the section, but it would still be huge improvement.
As for how to do the Material Section Fills… I think section fill by Tag in the Tag menu would probably be easiest, though I could also imagine a “section fill material” option in Entity Info for any group or component.
Sketchup provides so many possibilities, simply by being so simple. In the beautiful picture you attached, only the engine block is sectioned. Were I try to that in Archicad or Revit or Vectorworks, where sections tend to global and do not have the option of being placed inside individual bits of geometry… I imagine that would require a lot of workarounds. Whereas in Sketchup, it’s do-able with only the work-around of needing a 2D object for your section cut material. Imagine, though, if you could assign that diagonal hand-drawn material as the default section fill, it would be even easier than it is now - no 2D object needed. And if you could assign one material to the cut through the block and other to the cut through the cylinder liner, then I’d be in work-flow heaven.
The fact that so much of my work has multiple section cuts at varying distances from the camera is one of the strongest incentives for me to keep using Sketchup. Archicad has the multiple section fills that I long for, but cutting individual sections in individual geometry? I don’t know how to do it in Archicad, I’ve seen if done (kind of) in demos, but not really, not like Sketchup. It’s kind of like trying to directly edit a parametric object. Vectorworks and Archicad get closer each year, but only in Sketchup can you simply open it up and make whatever changes you want.
Anyway, I’ve been using Sketchup professionally for 22 years, as I wrote earlier, but in all that time, I’ve given nothing back to the community. Kudos to you and the other Sages for all you do, and to all the amazing plug-in creators.
