Hi!
I’ve run into a problem with multiple face offsetting. I am using two plugins: Multiple Offsets (Sdmitch) and Multi Face Offset (Remus). Sometimes offset goes to the wrong side - outside instead of inside face. I checked normals - they’re fine, no faces are reversed. Everything goes fine when I use native Offset tool but, you know, it’s not too fast.
This problem was discussed there: [Plugin] Multi face offset • sketchUcation • 1 by CadFather but no solution was found. So maybe now, someone, something?
I attached my model which problematic faces. If anyone likes to take a look, you should have at least one of these plugins installed and perform Multiple Offsets or/ and Multi Face Offset on these faces. Some of the faces get offsetted properly (inside) but some get outside. So I guess there’s some difference in geometry between these two sets of faces but I couldn’t find it.
offsetting.skp (96.9 KB)
