Hi is there a way to input more than one Len(x) in the attributes definition for dynamic components? I want to create a footing where i need to define two different lengths for a trapezoidal footing shape.
Thanks
KJ
LenX (and LenY,LenZ) define the ‘bounding box’ of the Component. To accomplish what you need, you would have to divide the shape in multiple shapes.
Check this thread:
I have my trim pieces set as sub components in my main component and one end of the trim pieces are cut at a 45 degree angle. Tho top trim piece is cut at both ends at 45 degree angles. How do I adapt these pieces so they are the correct length for different size door. (i.e. If I have an 80" tall door that is 32" wide the trim pieces should have their inner length 11 80 1/2" (to allow for the door frame/casing) and the top trim piece should have it’s inner side have a length of 33" (Door width +…
