Problem with dynamic component ” EtagereCube”.
My problem, as you can see on the three screen captures i sent you, is that the angle of 45° of
the miter cut is not conserved when i modified either the thickness (in french épaisseur ) the width (Largeur) or length ( Longueur )
of the dynamique component.
Is there any function or equation that can solve my problem?
Regards.
If you use scales to stretch the piece, any angled geometry will be distorted.
You may want to model this as 8 pieces… Four sides and four corners.
Or, model each side as three “sub” components… A center piece and a 45 degree piece at either end.
Check this thread:
Thank you i will try this way.
Regards
