Sorry, I am not finding anything in search for this.
I am drawing up Plantation Shutters (with multiple individual shutters).
I want to rotate the shutters all the same amount at the same time
Perhaps with scenes.
I want to go from vertical to maybe 60 degrees or whatever.
Is there some easy way to grab all the shutters and rotate them in one fell swoop?
I’m pulling a blank and I’m sure it is easy.
Pretty new to SU but am learning and enjoying it!
Thanks for listening.
Bob
Can you share the SKP file so we can see what you’ve got so far? Is it an entire shutter you want to rotate or the slats on the shutters?
If they are all components you can edit one and rotate it and all will rotate.
OK, thanks for getting back with me.
I apologize for jumping before I took another look.
Box, you were right …
“If they are all components you can edit one and rotate it and all will rotate.”
I use components before, but something wasn’t right with it.
Maybe I did unique or something like that.
I redrew it and it worked like I thought it should.
Rotate one, and the others will follow.
Sorry for cluttering up the forum.
Thanks for checking in.
Bob
