I need to draw more accurately in LayOut and wonder if 3 decimal point or 4 decimal point would be posit;e.
Hi-
At the moment there’s no way to do this, although some people have developed work-arounds for specific situations.
I will add your +1 vote to the feature request for this.
Thanks,
Marc
Hi Marc,
Any idea when the 3+ decimal point for the dimension tool will be implemented?
When will the “moment” happen when I will be able to place three and four decimal point measurements using the dimension tool in Layout. At present, I have to manually insert the required measurement and this is time consuming as I have hundreds of measurements. If it can be done in SketchUp then why not in Layout?
This is a MUST as far as Im concerned. If you can add 4+ decimal places in SU then why on earth cant you detail that out in LO - very frustrating. I actually can’t believe that in MM the accuracy is only to 1 decimal place! I work for a furniture maker and need to be able to detail and dimension laminate thicknesses and offsets for CNC details. With only 1 decimal place this is impossible and as Astokes said its time consuming and inaccurate having to manually input and the subsequently update dims to work around this! I hope its sorted soon.
Hi all-
This is one of our most important long-standing feature requests.
I can’t guarantee a delivery date for this feature, but I will say that the recent implementation of persistent IDs has finally paved the way for this feature to be completed as well.
Thanks for your patience.
M
Hi Marc, for whatever it’s worth, I vote for the same options as in SU, so 6 decimal places for dimensions and 3 decimal places for angles. Loving the new 2017, btw; associative dimensions are the bee’s knees…
