Models by Royce
A. Wren House #1.skp (171.9 KB)
Wrens have caused us problems because of their nesting habits. They started out building nests in places that could be raided by snakes that ate the eggs. Then they built a nest in our roof guttering - just to be washed out during a rain storm. Then they moved onto the patio and made nests on shelves. They use lots of moss, dead leaves and other things that had to be cleaned up. Finally, this year a nest appeared on my bench top with five eggs. Three chicks lived until fledging. Two fell off the bench during nighttime and died. So I modeled this Wren House with a friction fit entranceway on each end for ease in cleaning out after the chicks leave the nest. I might have to leave one entrace open, because I don’t know if the wrens can fit all their moss and leaves through a 3/4" dia. opening. :face_with_raised_eyebrow:
From: https://www.birds.cornell.edu/k12/educators-guide-to-nest-boxes/
A. Wren House #2.skp (172.3 KB)
This has the proper sized through-hole thanks to @fxcutting .
A. Drawer Slide #1.skp (330.2 KB)
This wood bottom mounted, Drawer Slide looks like it would be worth trying, :triangular_ruler:
A. Drill Bit Hanger #1.skp (233.8 KB)
I watched a video about a drill bit hanger at the Woodsmith Magazine website. It used an aluminum bar to hang the bits on instead of using a rabbet and tongue as I did in this model. I quickly realized that if I model all the bits I have with the grooves that the model would get too heavy. :upside_down_face:
I think it needs some diagonals..
A. Drill Bit Hanger#2.skp (296.3 KB)
@tweenulzeven - Here’s a version with diaganols. :wink:
I meant your drawing of the scaffolding. I’m not to worried about your drillbit hanger sagging :slight_smile:
A. Scaffold #2.skp (995.7 KB)
This is the corrected Scaffold with diagonals as @tweenulzeven advised. I only attached the scenes that changed. The model was heavy after adding the diagonals and the hardware. :wink:
A. Mitered Leg Joint #1.skp (479.3 KB)
Back in June 2023, Issue #303 - Tim Coleman had a master class article in Fine Woodworking where he showed a three-way mitered leg joint. This model was based upon that. The details of the table are mine. :carpentry_saw:
A. Button hole box #1.skp (326.0 KB)
The idea for this box came from a Woodsmith Magazine video where the button stands were shown. The box isn’t the same, but both boxes have mitered splines. The button-holes are on the bottom. :laughing:
A. Stamp Box #1.skp (167.7 KB)
This box is in the recent Wood magazine, Issue 312, November 2026. Instead of white oak recommended in the article, I’ll use some pine from an old couch frame I’m reusing. There’s a full-size pattern of the Side in the issue that I can use to trace the curves. The through-hole for the Copper rod that links the Lid to the Side is placed 5/8" x 3/16 (up from the top of the Back/Front) in the article. That didn’t work in how I modelled, though. I’ll try the magazines pattern first without drilling the holes.
A. Shed Floor Plan #1.skp (502.4 KB)
I revisited an old folder and added framing for a 10’ x 12’ shed. I used the Carpenters’ Square to model the bird’s mouth on the rafter. :wink:
A. Candle Carousel #1.skp (1.2 MB)
This model is based on a Woodsmith magazine article (Vol. 38/No.286). I got carried away with the deer carvings. The Buck is kind of clunky compared to the Doe and Fawn. The Stucture could support other kinds of carvings and accoutrements.
A. Smart Phone Holder & Stand #2.skp (125.5 KB)
Here’s another smart phone stand. :face_savoring_food:
Edit: Sorry, I forgot to hide the text in the Exploded; X-Ray; Hid. Geo. skp. :face_with_hand_over_mouth:
A. Wall Mounted Shop Bins #1.skp (311.0 KB)
Woodsmith Magazine’s The Complete Small Shop has this ingenious bin system and will come in handy in my future shop. :cowboy_hat_face:
A. Air Cleaner #1.skp (313.5 KB)
This is another model out of The Complete Small Shop. The spacing of the Cleats and the size of the hole in the Mounting Plate depend on the sizes of the Blower and filters.
A. Flip-Top Stand #1.skp (670.7 KB)
Another model based on The Complete Small Shop that comes from Woodsmith Magazine. I could see mounting two bench top machines like a Planer and a Jointer on this. The book said to be careful once the locking assembly is disengaged in case there are weight differences in the machines causes them to start flipping on their own. :grinning_face_with_smiling_eyes: This could save some space in a small shop. I have one difference from the one in the book in that I used four inch casters instead of 3 inch. I did not do a separate scene for the casters. I borrowed the casters from another model I made. Sidenote: I always find mistakes when I explode the model and find double copies of components. not all the mortises being completed, not all of the tags made for unique components, and stuff like that. :sweat_smile:
A. Workcenter #1.skp (1.5 MB)
This is based on The Complete Small Shop by Woodsmith Magazine. I made some changes. I only have half of the shelves. The other side of the Box of the case I left open to accomodate a stool, providing a space for carving and sharpening. I added a Drawer there for storing carving gouges and sharpening gear. I couldn’t find a flip stop quite like the one in the book, so I used a Rockler flip stop. The scenes are busy because there are so many components and labels. You will have to open the Skp and zoom/orbit to see everything. :face_with_head_bandage: Edit: I had a skin cancer procedure right where the bandage is on the Emoji.
A. Corner Shelf #1.skp (361.1 KB)
My wife saw a picture on the cover of Wood Magazine, Issue #312 of this shelf and said that she liked it. So, I modeled it with one change by putting a 1/8" arc on the top outside edges of the Shelves. I thought it would be relatively easy, but the biscuits and their placement was a little tricky. :sweat_smile:
