Models by Royce
A. Hinges #1.skp (512.9 KB)
I decided to start making more hinge models based upon dimensions in catalogs.
A. Horton Brasses, SL 6 Butler Pantry Latch #2.skp (917.8 KB)
Here is more Horton Brasses hardware.
Edit: I updated this when I noticed that the Latchbolt Catch didn’t meet the Latchbolt
correctly and the orientation didn’t match the image. I edited the screenshots and deleted the old screenshots.
A. Compass Slicing Gauge #1.skp (330.1 KB)
This is based on the image of a Steve Latta - Circle Cutter that used to be made by Lie-Nielsen. I used my own dimensions that seemed about right to me.
A. Slicing Gauge #1.skp (359.2 KB)
Another model based on the Steve Latta stringing tool set that used to be made by Lie-Nielsen. Again, these dimensions are just my best guess.
A. Stringing Thicknesser #1.skp (477.9 KB)
The last of the Steve Latta stringing tool set that Lie-Nielsen used to make is a Stringing Thicknesser that is fastened to a benchtop with an F-clamp. The dims. are my best guess.
A. String Mortise Cutter #2.skp (56.3 KB)
I remeber Michael Fortune had an article about a tool like this in Fine Woodworking Magazine, but I don’t remember the date or issue number.
Edit: Re-posted the skp with correction as seen in @mihai.s ’ video.
What is it used for?
It is used to make a thin groove for stringing. Only straight lines, though. It would not work for curved lines with changing wood grain directions.
:wink:
A. Panel with Inlay.1, #1.skp (215.6 KB)
Steve Latta, “Add Pop to Panels,” Jul-Aug 2018, Issue #269 FWW magazine - is the reference for this panel with Stringing.He routed with a Dremel with an end mill 0.030-in. and 1/16 in. cutting diameter. He had a Stewmac.com Plunge Router Base #5806 with the Dremel.
He explains in the article that he had to stop short of corners and start again after them, and then he came back with either a chisel or small gouge to cut the corners. He also glued the three inlay strings together in small length segments and clamped them with paper clips. Can you imagine?
A. Spoon Style #1 - #1.skp (67.6 KB)
When in doubt, just model another spoon. It’s good practice.
A. Quadrant Hinge (Brusso Hinges) #1.skp (791.5 KB)
The reference for this hinge is Fine Woodworking Magazine, “Quadrant Hinges,” Adrian Ferrazzutti, Issue # 207 (Sep-Oct 2009).
A. Viola Latch #1.skp (1.6 MB)
I tried to find the latch that Adrian Ferrazzutti used in his article. Lee Valley no longer carries it. I found one similar by Viola of UK. This one has a fancier escutcheon. It would be a challenge making the mortise I’m guessing with gouges and chisels.
