Delete unnecessary detail in the model. That is by far the most effective method to speed things up.
Yes, a little. also, turning off shadows and profiles helps a little.
Very slightly. Component nesting has some impact.
Look in Task Manager: if Windows uses more memory than available (resorts to virtual memory) then an upgrade helps. GPU upgrade, if you already have a somewhat modern one, has quite a slight impact.
