Hi! I’ve been trying to import a HQ model of type .dae collada using the extension Skimp. The reason i’m using skimp instead of the standard Sketchup import is because i need to keep the layers/groups information in the model, which the standard import removes (the entire model becomes a single component.
The problem i’m having, which i know others have struggled with is the missing faces that appear at curved edges, probably where there are small faces.
The solution i’m finding for this online is to scale up the model in Blender or similar and then import and scale down. but no matter the size i try in blender the imported model in Sketchup is identical. (I’ve tried to scale by a factor of a 1000x and it made no difference other than becoming impossible to view the entire model at the same time.)
The way i’m scaling it up in Blender is by increasing the scale of everything in the scene and mouse drag scale it up untill it’s x times bigger.
Any help/tips on how to solve the problem?
At 100% quality:
At 10% quality:
Skimp import settings:
