Metric conversion
How do I change scale to metric and back to normal
Look to the Top Menus…
Window > Model Info > Units
With the web version, bottom icon on the right side.
What Box said, with a picture.
BTW, even when you’re using an English system template, you can draw things using metric units by typing the units (m, cm, mm) after you type in a number. If you want the tape measure or dimension tool to read out in metric, then, I think, you have to change units as described above.
Who said Imperial is “normal” and not metric?? :grinning:
