Can someone please assist me with merging shapes which have been drawn on sides of a rectangle box and push/pulled to create a shape that is of the intersecting portions of these shapes? Please see attached pics for referance.
If you are using groups / components - edit the group / component, triple click to select all, right click ‘intersect faces… with model’ - then selectively delete lines / faces as needed.
If you are using Pro and you have properly built solid groups or components then you can use the solid tools.
Thanks Mike, I have a reasonable understanding of compnents. Should I make each different shape its own compnent or group the whole model as its own component. This is how my model starts…
Here it is in its most basic form, pushpull the shapes through each other then use Intersect to make all the edges cut the faces, then delete the excess.
