It is that time of year again and with a few more updates added to the Wall, Truss and Foundation plugins it makes sense to encourage everyone to upgrade to the latest versions of the plugins.
In an effort to get as many customers up-to-date and using these new feature I will be offering a renewal promotion on all the plugins during the Thanksgiving holiday (Nov. 23 - Dec. 5).
The regular license (renewal) prices are given below:
These promotional prices will take affect Nov. 23, 2022 and end Dec. 5, 2022. All renewals, prior and after this time frame, will be at the regular price, unless superseded by a previous or future promotion. No rain checks will be given, and this promotion only applies to permanent licenses and not to subscription licenses.
Please note that if you have recently purchased a permanent license for one of the plugin(s), you can still take advantage of this renewal offer. Renewing your license while it is still active simply adds an additional year to the license expiration date and future proofs you for upcoming updates and releases.
This is a fairly substantial discount in hopes of getting as many users to upgrade to the latest versions of the plugins as possible. In the last year, the updates to all the plugins have been fairly significant. I would very much like to see everyone taking advantage of these updates and utilize the new and improved feature that have been added to the plugins.
Thank-you for your continued support and for your continued interest and enthusiasm in the development of these plugins.
Nathan,
Curious about something I noticed in the estimating tool. Is the tool calculating both layers of drywall? From what I’m seeing, it’s just running the square footage for a single layer. I was wondering if there’s a setting I didn’t turn on, or some other “gotcha” I may have missed. Thanks again for such a great product.
The mdkBIM promotion has ended (Black Friday) however a lot of existing customers seemed to have missed the renewal promotion during the Thanksgiving holiday so I will be extending it until Christmas.
My bad: I used a comma in a material name, which made a bad material, and now it can’t be deleted. I keep hitting the delete button, but it won’t go away.
Also, why can’t I select my material for stair stringers? The choice is limited, and my custom color isn’t among the choices.
Note that framing dimensions (elevations) and plan dimensions (plan view) can be turned on and off independent of each other in the global settings. Also the additional offset parameters allows one to adjust both offsets independently as well. However both dimensions are placed on the same layer (at least for now).
Currently the plan view dimension option will assign an overall dimension for the wall length and then separate dimensions for windows, doors and garage doors. I do not have it inserting dimensions for more custom features like Simpson Strong Walls or in-wall columns.
Digging through my notes and todo list this afternoon. I noticed that when you do not install a door and you choose an option other than Option C (Gypsum Only) for the casing then their is no internal casing installed as shown below
My reasoning behind this is that in this particular case you would probably choose not to install the door because you have provided your own custom door for the opening, so no interior casing is needed or wanted.
However, where the wall is an interior wall there is a possible additional case where you simply want to have a framed opening between rooms without a door. In this situation you do want the interior casing provided.
This casing would only be instantiated if the install door option was turned off.
However it makes sense to have this option available on a door-by-door basis:
Jamb Interior: YES/NO
In order to not overly complicate the matter I will assume the same shim gap as the typical pre-hung installed door and the interior jamb thickness will be the same as the jamb thickness (typically 0.75 inches).
Just cleaning up some loose ends before the start of the New Year.
One issue that is sometimes encountered is when a custom material is defined in the Material Library and then after using it in a Wall Preset it is subsequently deleted.
When this happens and that particular Wall Preset is loaded the plugin tries to assign that custom material in the Draw or Edit wall menu. If you try this you will quickly notice the drop down box for the material is blank and no valid material is selected. This inevitably leads to an error either being thrown within the plugin code itself or within the javascript of the HTML menu pages (not sure which at this point).
I need to devise some error checking in the HTML/Javascript to detect this problem if it pops up and gracefully resolve it rather than locking up the plugin. If I can fix this it will not only save the end user from annoying headaches but also eliminate unnecessary support calls and emails for myself.
I’ve had quite a few requests for ICF walls in the past few months. Apparently this method of construction has some popularity even though it may not be as common as traditional framing. I may consider adding this as an additional option for the Wall plugin.
From a programming standpoint it really isn’t too different from the CMU option, the only real complication may arise when dealing with t-intersections with other ICF walls, but I’m sure I can program my way around that one.
The corner configurations are a bit more complicated than CMU or NO FRAMING however it is essentially the same from a coding and geometric standpoint.
Doors and windows involve cutting through three solids (insul - conc - insul) instead of one.
My only concern is whether or not to make the concrete and insulation thickness configurable at a global level or at a wall level. I supposed there could be situations where different ICF sizes could be used on a single project? Thoughts?
