Last night I was giving some serious thought to the subject of floor trusses. My initial thought was to move them to the Floor plugin or at least create a floor truss module within this new plugin. But after further consideration it seems like I would just be duplicating a lot of work with no serious gain in functionality. What led me to this conclusion is that floor trusses are generally used in a rectangular layout not a polygon. In fact, I’ve never even seen a floor layout with floor trusses in anything other than a rectangular format.
What I do need to do is spend some quality time updating the existing floor truss module in the Truss plugin. I’ve already identified a number of issues and deficiencies. That is the plan for now with floor trusses.
Version 0.9.1 was when I enabled the global offset for joists however it appears that this offset is not being applied to blocking, metal bracing or insulation. I will need to work on this:
There has been some call for this product line so I am working on the algorithms so that it can be configured properly. It is a bit more complicated due to the directional nature of its trimming panel (only one end can be trimmed).
Added the following TriForce Open Joists: OJ3-11.875, OJ4-11.875.
I will probably add in the 14" and 16" Open Joists in a few days, or as requested.
FYI, I carefully studied the manufacturer’s literature, and the models provided by the plugin (even though slightly simplified to decrease the poly count) should be quite dimensionally accurate and compare very closely to the real product. In other words you should be able to plan your ductwork, electrical and plumbing around these models with a fair degree of accuracy.
+1 for RedBuilt products or your facsimile of open web trusses with tubular steel webs – we would specify these more than Triforce only because of regional availability and being listed approved products by governing agencies. We’ve used these open web type trusses (as opposed to TJI or similar with solid web) in many high-end residential projects because of a combination of large spans and having to accommodate mechanical ducts, plumbing, etc.
Looks like our typical projects with framing going in every direction compounded by depressed framing in particular areas with various conditions to allow for hard rock concrete, gypcrete/acoustic underlayment, thick hard surface floor finishes, waterproofing underlayment/drainage systems, etc. – all to maintain a level floor finish surface for accessibility compliance.
Bah! Yeah it’s big, but that’s still all rectilinear. Not like my house. As I may have said, a client once threw down the gauntlet before me: “No curves, no angles, and no changes in level.” Naturally I had to get all of those into my house.
My father, a senior estimator for a commercial framing and finishing company, has watched me and had me draw stuff for him using your tools and was amazed, but sad that they are not more integrated with commercial building solutions. This coupled with the CFS framing material will make him happier
