Hi,
I have a problem with an dynamic component.
This is a component which I use in a bigger dynamic component, but I cannot change the material in here either.
I hope someone can help me wit this.
Thanks in advance.
Hi,
Thanks in advance.
you have painted the surfaces “RAL7016 alu” and back surfaces “8” green
these overrule the component material which is painted red. by changing any of the raw surfaces to default, the red will show
this ability gives you greater control when used with a deep surface, painter, many found in extensions
Goot_zijkap.skp (32.4 KB)
Thanks!
