Material assignment problem
There seems issue with assigning materials for correct render. I have skirting modelled but Enscape ignores them. Lightings don’t show either. Assigned materials/colours hardly seen. What am I doing wrong?
Hard to say unless you share the .skp file. If I had to guess I’d say that your skirting has the faces reversed but that’s only a guess.
If you can have a look at the model that will be super helpful. Unique Download Link | WeTransfer
Show a screenshot of the render with the problem. I don’t see anything I would call skirting in your model.
Something is weird with your model. There are two Xray styles that, even when they aren’t used in any of the scenes, cannot be deleted and result in a Bug Splat. I wonder if @colin can take a look at the file and see what’s going on.
DaveR thank you for having a look at the model.
I figured out that an element was covering the skirting - so the elements close to the floor was ‘buried’ so were the skirtings. They are now visible.
But the issue with the materials remains the same.
