I’ve been using the default text and dimension size when attaching Dims to my drawings. Problem is that when I export to Layout the size of the Dims text and numerals is much bigger and crowds the drawing. Tried to adjust in Layout but it doesn’t seem to work. How do I set the dims / text size in Sketchup so that it exports as a smaller size?
It’s better to put the text and dimensions in using LayOut’s tools but if you must use SketchUp’s tools, you would probably find you have more control if you set the text size by Height instead of Points.
