Making guides and pick points with tape measure
What do have to do different to make horizontal versus vertical guide lines with the tape measure? Also, what makes the tape measure place pick marks?
Thanks
If you click on an edge, an axis line or an existing guideline and drag away from it, you’ll get a guideline that is parallel to it. If you click on an endpoint or an intersection you’ll get a guide point. If you want to set a guideline at an angle relative to another guideline, edge, or axis line, you the Protractor instead of the Tape Measure tool.
Thanks
