Good day everyone! I am really new to these forums…but I figured that this would be the best place for me to ask about creating something. I recently upgraded to sketchup pro!
I am having trouble creating a Y pipe manifold in sketchup. Has anyone done this and if so could you please explain how to.
Start by using the line command and arc command to draw the path of one half of the Y
The draw a circle at the end of the path the size of the final pipe
Use Follow me to create the volume of the pipe (circle along the path)
Select all (I inverted faces) and use Rotate (with modifiers key) to copy-rotate the geometry
Select all and intersect with selected
Cleanup! (remove interior faces, smooth/hide lines.
Sorry for dragging up a long finished thread. but Im currently struggling to achieve this, im still rather new to sketchup so unsure what you mean by Select all (I inverted faces) and use Rotate (with modifiers key) to copy-rotate the geometry.
I was wondering if you could explain how to go about this.
