Making a smaller part of an old component into a new component.[Uploading: Screenshot 2025-04-07 at 11.51.18 AM.png…]()
Hexagon A Apr 7.skp (207.3 KB)
Hello, I’ve hidden most geometry in my model. What you see here is a single component. I drew lines on them because I want to change the middle piece into a new component.
All Forum answers I could find on this topic wanted me to use Make Unique. Whether I double click or single click on the component, I cannot find Make Unique. (Except for the single click option in which Make Unique is greyed out.)
So, how do I make that middle section into a new component?
Peter Enns
Double clicking on a component opens it for editing.
Make sure that the Entity Info is open and single click on the component to select it. Observe the Entity Info window to see if you have a component identified. If it is the case, right clicking shall open the contextual menu where you can select Make Unique.
If unsure, upload your model in your next post.
Hexagon A Apr 7.skp (444.0 KB)
As you can see, the SKP file has been uploaded. And, in the screenshot, you can see that the Make Unique option has been greyed out.
Any other ideas?
Thank you.
Peter Enns
It’s clear in your screenshot that the component is singular, as in only 1 in the model. You cannot make something unique when it is only one, unique to what?
Peter, could use some clarity about what you want. Do you want a new component of the center section without changing the geometry of the original or do you want to totally remove the geometry of the center section from the first component and replace it with a new component of just the center geometry.
I wish to keep the old component and change the middle section into a “subcomponent”.
Peter Enns
Hexagon A Apr 8.skp (4.2 MB)
Here’s a new copy of what I’m trying to do. I get it that I can’t make this half perimeter unique. The entire half perimeter was selected.
But I still do not have a clue how to make the part of a perimeter that you see in this image into a component. The new component would be part of the old component.
Peter Enns
