Hi all
I need to draw a grid of 600mm x 600 for a 550 sq mtr ceiling - is there a quicker way than drawing the lines over and over again till its made?!
thanks Robert
You should be able to do 2 linear arrays to create it. Do you know how to use ctrl with the move tool to make copies?
Or using Extension:
e.g.
https://extensions.sketchup.com/extension/f0f7b594-d798-4ee8-bbab-1155554daa2d/guide-toys
Or
More here
https://extensions.sketchup.com/search/?q=grid
Dezmo! Grid tool extension ! I’ll try that ! cheers
oh that works ok too - I will do set of 600x600 and then just copy and connect them along
If you make one ‘tile’ as a component and then array them, any changes to one will be reflected in the others.
You can use the Sandbox tools as well.
Except for the hidden diagonals.
But they can be selected separately to then delete them.
That, or use something like the free CleanUp extension or SelectToys to select those crossing lines.
I just create a square the size i desire, lets say 8.4m x 8.4m column spacing… make it a component, delete the internal face… create a grid tag “-GRID-8400”… choose a dashed linestyle… array the component to cover the area of interest in your model… pretty simple and flexible
All good answers but I’m curious whether the OP actually wants a grid of guides or a structural grid of edges.
