Hi I have upgraded to the latest release of Sketchup Pro.
Is anybody else having issues with Sketchup loosing focus? Often when I move to a top view it looses the model and all I am left with on the screen is the axis. I have also had this when editing within the model. It will suddenly loose the model or the component completely? It is the same in parallel or perspective mode.
The last time that it happened I got the dreaded NOT RESPONDING message.
Hard to say what is going on. Can you share a SketchUp model file where you are seeing this? Typically when this sort of thing happens it’s because the user has some tray geometry at a huge distance from the rest of the model and they hit Zoom Extents. That isn’t unique to the latest version, though.
At least show us what you working with so maybe we can duplicate what you are seeing and help you out.
The zooming now sets the camera position in parallel mode. So if you’re working in parallel, the camera could be way off.
(This behavior changed with 2020.1)
So the order of setting up the top view becomes more important, best to save a scene for that.
FWIW, in SketchUp, it has always been intended that modeling be done with the camera set to Perspective and Parallel Projection used for creating views for output.
You can do that however it’s not the way SketchUp was intended to be used. As you’ve already found, you are likely to induce clipping and as we have seen many times, even today from another user, it’s easy to wind up with the camera located at such a great distance from the model that you won’t be able to see it. Sometimes Zoom Extents isn’t enough to correct it. Basically, do as you like but do it knowing the potential problems you can induce for yourself.
There is an excellent extension that unclips when in parallel projection… When it doesn’t work, I flip to perspective, reset the FOV and then it corrects itself. So far it has worked a treat but thanks for the warning. Always appreciated.
